I recently picked up a 1572, like all it needs drive line work. I’m thinking going the cyclops route. The trouble I’m finding is there is not a length list, I know the standard answer is to have Jeff in pa make one or use a 1863/64 driveshaft.
Without pulling it apart it’s hard to get a length, what is the required length? Also I have 4 cyclops driveshafts, maybe more, not all are marked as to what they where removed from. Is there a master list someone has made? |
Joe,
Go here and look them all up, the lengths are in the parts list. When you are done make a sheet for all of us to see. ![]() https://www.cubcadet.com/en_US/ari-partstream.html#
Lots of hunting and pecking there... it will work, but I’m trying to figure out what’s on the shelf upstairs too...
While I’m thinking and posting, has anyone tried running the CV driveshaft without bolting it to the pump? I know I can pull the rear and swap pumps, or drill out for the 1/4-20 bolt to hold the adapter on, is it necessary?
I think Parts by Jeff, the sponsor at the top, makes a pump drive that uses the roll pin. Not sure if he has done that, but he could most likely.
