Old 01-08-2021, 09:12 AM
Luke Workman Luke Workman is offline
Default 782 Loader Project
I have a question. I have a 782 that I would like to build a loader for. Would the stock hydrostatic on the 782 be enough to power the loader?
Old 01-08-2021, 03:54 PM
No, you will need an auxillary Hydraulic Pump.
Old 01-08-2021, 04:07 PM
Oh ok, I just saw this loader and I wanted to build something like it ( the pictures and story on the loader is farther down on the page).https://www.redpowermagazine.com/for...cadets/page/3/ I think this is a really realistic design and the builder specifys that it is run off the regular pump.
Old 01-08-2021, 04:16 PM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
The charge pump only puts out a few gpm... that thing's hydraulics must be pretty darn slow-moving!
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 01-08-2021, 04:25 PM
Ambush Ambush is offline
That's a coincidence. I was just looking at an older thread about loaders and there was a pic of that very tractor. From what I can learn, it seems that the loader pictured is a down scaled version of a 2250 loader from much larger tractors.
I'm also doing a loader build for a 149 and I have a dedicated pump for the hydraulics. I think it's wise to keep the piston pump/motor separate from the contamination possibilities of the loader system. The hydrostats don't do well with any contamination.
I'll be watching for your progress.
Old 01-09-2021, 02:13 PM
Well, I am sorry to say that I most likely won't start the loader project until I have enough money and the tractor's ignition coil is replaced (I bought the tractor with a kohler mag 18 and the coil went bad a few months ago). I may start on the project next year or so, I just wanted some answers to if that loader design (or something similar) would work.
Old 01-22-2021, 08:37 PM
Ok update everyone: My tractor's coil has been replaced and it is running now. Once I get my 3 point hitch and sleeve hitch installed I am going to start saving money for the loader.
Old 12-29-2021, 12:33 PM
Farmall450's Avatar
Small cylinders would be fine. Take the deck lift, for example.
I'd be more worried about not having a large enough reservoir in the rear end, personally.
