Old 01-11-2021, 03:24 PM
R2JOHN R2JOHN is offline
Default Original Cub Engine Mounts
I am restoring my 61. When I pulled the engine of the frame there was spacers under each bolt. I checked the parts book and did not see any listed. Nothing in the service manual that I could see. Any one see this before. Thanks.
Old 01-11-2021, 03:44 PM
I looked through both my TC-82 and TC-113 parts catalogs and I did not find that either. I am going to say a PO modification.
Old 01-11-2021, 06:18 PM
Maybe the oil pan is not flat on the bottom.
Old 01-12-2021, 08:52 AM
Maybe someone decided that shims would give better drive line alignment.
Old 01-12-2021, 09:54 AM
Quick and dirty belt adjustment?
Old 01-12-2021, 11:04 AM
Ambush Ambush is offline
Maybe the pan was milled at one point? Or the mounting frame replaced and lowered a bit?
Old 01-12-2021, 11:28 AM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
This seems likely, but rather pointless considering you just loosen 2 bolts, and then get some pry bar action
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 01-12-2021, 11:41 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Or maybe the frame floor is bent.
Plow blade
#2 Cart
QA36 snowthower
Old 01-12-2021, 06:30 PM
Thanks for the input. I checked the frame and it is flat and true. Oil pan does not seem to be modified. I install the engine without shims. New belt and adjusted properly!
Old 03-17-2021, 04:06 PM
All done! My 61 Original. I installed the engine with out the shims. Belt runs true.
