Old 01-22-2021, 05:58 PM
Ambush Ambush is offline
Default Heel/Toe vs Two Pedal Control
For those that use either, or especially if you have experience with both, I'm looking for the pro's and con's of both. This will be almost exclusively related to using a FEL. And I will retain the dash hand control with either choice. The two pedal is more work to build, but not enough difference to have that affect the decision. Thanks.
For a hydrostat, of course.
Old 01-23-2021, 06:12 AM
Most of the 2 pedal setups are on a common rockshaft. This is a 2000 series cub.
Old 01-23-2021, 07:12 AM
MSS7120's Avatar
MSS7120 MSS7120 is offline
What's FEL? spelling error, or does that mean something?
I have used both. I have used the 2000 series shown above. 3000 series with two peddles side by side. And CaseIH Farmall 35 with a nice cast iron treadle style peddle.
My least favorite is the 2000 series. The treadle style is really nice for changing direction. The operator can modulate the hydro to drive and mow into tight corners and seamlessly change direction to back out. That's the advantage of one peddle. with two peddles you have to stop and move your foot. It's not as smooth.
Mark from Minnesota
3165 with CC Snow Blower, Front blade, Sims Cab
3185 with 3pt hitch, it runs now. But not well.
48in and 52in mower decks
2185 with mower from my dad when I have a project for it.
Massey Ferguson Model 70 corn planter.
CC yard cart
Old 01-23-2021, 07:44 AM
Getter-Done's Avatar
Getter-Done Getter-Done is offline
FEL is an abbreviation for Front-End Loader.
I am in the process of building one myself.
Old 01-23-2021, 07:55 AM
I have a FEL project I have started.
I plan to fabricate a pedal similar to the one pictured below.
I hope to use expanded metal mesh in the center
and angle iron and pipe with bushings for the frame.
Old 01-23-2021, 07:56 AM
.Bottom view.
Old 01-23-2021, 08:01 AM
MSS7120's Avatar
Thanks, hard to keep track of all the TLA's = Three letter acronyms
I'd use the single peddle treadle style design. If you want to drive into a pile of gravel and scoop and change directions all smoothly and simultaneously it's the best. Assuming your leg and knee and ankle joints are good you can smoothly rock your foot and change your motion. Two separate peddles require full stop and pivoting or lifting and moving your foot to the other directional peddle.
It comes down to what ever you like best and will work for you.
Mark from Minnesota
CC yard cart
Old 01-23-2021, 08:03 AM
MSS7120's Avatar
I like it. Keep what you got and modify over time as you learn more about what you do and don't like about it.
Mark from Minnesota
CC yard cart
Old 01-23-2021, 08:18 AM
MSS7120's Avatar
I recommend you take a look at the hydro peddle on a Cub Cadet SLT1554 and CaseIH farmall 35. Haven't found a good photo to share yet. I"m looking through tractor house.com now to see if I can find one.
Mark from Minnesota
CC yard cart
Old 01-23-2021, 08:43 AM
Like this one?
