Old 02-01-2021, 11:29 AM
snackman508 snackman508 is offline
Default QA36 on 1512 belt size help
Ive got a QA36 converted to a wide frame and its on my 1512 Diesel. the blower has a 5/8 pully on it. Some one said the IH-78056-C1 Belt (5/8" x 36-1/4") should work. Any one have a cross reference belt that works. Called my local Napa that dose a lot of farm/industrial stuff and they couldn't find any thing. Or if your running a different size on a similar set up.
Old 02-01-2021, 12:09 PM
QA36 snowthrower was NOT designed to fit on a WF Cub Tractor. The QA36B would be the correct snowthrower & fit.
If it was done correctly, then three modifications are needed.
(A) The drive pulley on the QA36 would have to be changed out
(B) A new Drive Belt is needed
(C) The upper control arms need to be changed
Old 02-01-2021, 02:13 PM
Just go to TSC and pick up a few belts, 37",36", 36.5" whatever.
Up to 534 and counting...
