Old 02-25-2021, 05:39 PM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
Default Kohler Command engines from other brands
I have a 1980 782 with a series I Kohler 17. Approx 60% of my property is slanted, not flat, so I want to put together a premptive list of drop-in of Kohler Command engines. I have a list of Cub Cadet engines but was hoping to add to that list other brands and models that would also have drop-in engines. Deere, for instance? Anybody know of any specific non-Cadet engines to put on the list? Thanks.
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 02-25-2021, 06:29 PM
FWIW:
If you are worried about sloped property blowing up the engine, it is not from that.
Most KT series 1 die from lack of frequent oil changes and revving a cold engine before the oil is warmed up.
They are a splash oil system to the connecting rods. with about #5 oil pressure.
The series 2 and magnum engines were much improved with full pressure oiling to the cross drilled crankshaft achieving #80 cold and settle to about #35 hot.
They are a bolt in replacement for the series 1, although an old engine flathead design, and not available new.
I don't have an answer to the command swap, as I prefer the old opposed twins.
