Old 03-07-2021, 02:15 PM
That_cub_dude1847 That_cub_dude1847 is offline
Default Oil Bath Air Filter is restricive
I have a cub original with an oil bath air filter. It seems to run great with it off but as soon as I put it back on, it runs awful an sluggish. I would like to restore this air filter and have it back in working order so I can use it. Is there some kind of cleaning procedure I should follow? I'm not sure how to fix it.
Old 03-07-2021, 05:12 PM
DRohacek DRohacek is offline
Make sure that your oil level is correct in the cup. There should be a line about an inch or so long that indicates the oil level. The screen can be cleaned with carb cleaner. They are pretty straight forward.
Old 03-07-2021, 05:17 PM
Should look like this
Old 03-07-2021, 05:29 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Refer to the manual on page 5.3 in this link: https://www.onlycubcadets.net/forum/...ead.php?t=4646
Kerosene is the preferred solvent to clean the element and parts.
Plow blade
#2 Cart
QA36 snowthower
Old 03-08-2021, 04:28 PM
Ya, I've been filling it up to the correct level, its just the metal mesh i think is the problem
Old 03-08-2021, 05:01 PM
green407's Avatar
green407 green407 is offline
I would soak that "mesh" with kerosene, or some other solvent.
128 X 2, 129, 149, 1250, 1450 x 2
Old 03-10-2021, 04:17 PM
Just leave it sit? For how long should I?
Old 03-10-2021, 04:45 PM
Wash it off with carb cleaner and blow dry.
Old 03-10-2021, 06:47 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Swish it around in some kerosene, and blow dry (from the inside to the out).
Repeat a few times and you're GTG.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
