I need to replace the rear axle on my 2182. Looking for a part tractor(s) to repair it. To expand my possible candidates for donor tractors can someone tell me what other model Super Cub tractors also used the same rear axle?
Thanks in advance. |
Here is one that's very reasonable. They actually have 3 in stock.
Not sure your year and serial number, but I used this one 2182 (145-743-100) - Cub Cadet Garden Tractor (SN: 821060 - 880000) and got the part number off of Partstree and did a google search, and this came up. https://www.ihccw.com/transmissions....roduct_id=1200
The Cub Pack. 70, 100 (creeper), 104, 122 (2), 1250, 1810, 1863, 2182, LTX 1050, SLTX 1050, SLT 1550, SLT 1554, Snow Chuckers 450, 451, 826T, 1030E, 2 plow blades. always looking for "just one more"
It says those are for garden tractors, not supers. Verify your part numbers before ordering.
There are four generations of the 2182. All of them use the #903-1806 Axle.
According to the Cub Cadet Parts Lookup site (Tab at top of page), these tractors models used that axle.
(Superseded to 903-1806) USE 903-1806 AXLE ASSY-REAR Link for you to look at https://www.partstree.com/models/218...le-carrier-47/
The Cyclops GT's also use the same axle. Trans axle is also the same in the Sundstrand tractor except for the reduction gear.
Super reduction gearing 6.8 : 1 Reduction gear 68 Teeth Pump Shaft 10 Teeth GT reduction gearing 5.5 : 1 Reduction gear 66 Teeth Pump Shaft 12 Teeth
Thank you everyone for your help.
