Old 04-07-2021, 09:28 PM
DSarow DSarow is offline
Default Carter Carb Question on C-26
On my K-301, I have a Carter C-26. If you take off the screw that holds the fuel bowl on there is, in the center threaded section a brass fitting, that looks removable with a straight screwdriver. What is that fitting called, purpose, should I remove and clean? What if I mess up the screw slot, if its original a d tight? Brass fittings can be a bear. Any thoughts and suggestions are greatly appreciated
Old 04-07-2021, 10:38 PM
It is called the main jet, yes it needs removed so you can remove and clean the emulsion tube above it and clean all the little holes in it.
custom grind a good screwdriver to fit the screw slot tightly and properly.
Better to find one in a hex drive that comes in some in packages meant for a battery powered screwdriver/drill motors.
then you can put a lot on tension on it in a vice and a 1/4" drive ratchet without worry of it slipping out of the screw slot.
