Old 04-09-2021, 09:28 PM
Ambush Ambush is offline
Default Carlisle Tru Power Lawn & Garden Tire
About three weeks ago I ordered two 23X10.50-12 Hi-Run Ag tires from a local big box store. This morning they sent me a message they were ready for pickup. I get there and they only have one tire and no longer available! I let them keep that one since they're so rare.
Anyway, I found a set of Carlisle Tru Powers for a reasonable price. After using the search function I found that a number of guys use this tire, but I figure I better confirm them for my application. No mowing, front end loader, tiller and disc and might be looking for a bottom plow and harrow. They will get filled and run about one hundred pounds of weight on each tire and a potential one hundred and fifty pounds out back. And it's on a 149. Good for all that?
Old 04-10-2021, 12:27 AM
CadetTommy's Avatar
CadetTommy CadetTommy is offline
Absolutely. They're good tires. I have mowed with them for years too, they're fine for that as well.
'74 IHCC 108 - 38A, supersteer axle
'75 IHCC 1000 - 44A, Sears wheel weights
'87 CC 1872 and 1811 - Haban, 44C
'96 CC 1863 - 54GT
'79 JD 400 - 60" deck
"Projects" '67 123, '65 102, '71 126
Old 04-10-2021, 08:04 AM
I agree. I run Ag tires on my 784 and never looked back.
Old 04-11-2021, 10:24 AM
Those are great tires to use for ground (dirt) engaging equipment.
Old 04-11-2021, 01:27 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I think the Carlisle will far outlast the Hi-Run. It's money better spent.
Plow blade
#2 Cart
QA36 snowthower
Old 04-11-2021, 08:11 PM
I did the same for my 147.
Old 04-11-2021, 08:18 PM
Thanks men! I will order the Carlisle's tonight.
Old 04-20-2021, 02:00 PM
captclayt captclayt is offline
Default Cub cadet 1018
Hello,
Today I was mowing my lawn after servicing my B&S 18.5 twin cylinder Engine.
About an hour into the cut I noticed a lot of smoke coming out of the exhaust. The engine was also losing power with the cutting deck engaged. When I disengaged the deck the engine would pick up in rpms. I stopped the engine and checked the oil only to find it to be way way over the fill mark and smelt like gasoline. I checked the gas level at the rear of the engine and the tank was empty. Three gallons gone in a mater of one hour. How does three gallons of gas empty into the crankcase in the matter of an hour? Their would have to be a direct path to the crankcase from the tank.
The engine starts on first revolution of started.
So far:
Plugs are new.
Pulse fuel pump is working.
Drained and removed filter. Put fresh oil and filter back onto engine.
I have removed the carb and cleaned it. The fuel bowl had s lot of junk in the bottom. I used carb cleaner on all the jets and ran fine wire thru all the jets.
I reassembled the carb and turned it up side down and blew thru the gas inlet and had no air coming thru needle valve I then turned carb back and was able to blow thru needle valve.
I did make the mistake of removing the dip stick while engine was running and got covered in gas/oil mixture. Luckly I was wearing my glasses.
Checked compression 125 and 150psi
Any ideas where the gas is entering the crankcase?
Old 04-20-2021, 02:33 PM
TheSaturnV's Avatar
Sounds like the carb float got stuck wide open.
Old 04-20-2021, 06:49 PM
jbrewer's Avatar
jbrewer jbrewer is offline
What "Saturn" said!
She's running rich....
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
