Old 04-17-2021, 12:12 AM
Ambush Ambush is offline
Default #2 Tiller Converted to Motor Driven.
I got the tiller with the tractor but there was no mule drive, belts or corner drive for it. And since I had a fourteen HP motor already from another project, that set the direction. I wanted the input shaft on the opposite side for better centering of the motor which meant pulling the cases apart and flipping it over. It all came apart relatively easy. And then the bad news. The sprocket is welded to the shaft its configuration wouldn't allow flipping it over. The case, sprockets and chains were coated in what I believe to be open gear grease, but it cleaned up good.
I found a piece of 3/4' shaft that was long enough to stick out both sides, incase I ever wanted to revert to the original belt drive. Cut a keyway and picked up a sprocket and hub and got that welded up and new spacer made to keep everything where it should be.
Old 04-17-2021, 12:22 AM
It seems JD Corn Head grease is the lub of choice to fill the chain case. Happily I discovered we have a brand new farm and garden JD dealer in town and darned if they didn't have that grease. Cheap too!. Just guessing, I bought six tubes.
I put everything back in the case and with it laying on its side, I got all six tubes in there and I might have got one more in. I welded a 1/2" pipe bung in the top of the case for future filling if it's ever needed.
You can see the inputs in that pic too.
Old 04-17-2021, 12:30 AM
Now to get the motor to stick to the tiller. That turned out to be fairly simple as you can see in the pics. A piece of 3X3X1/4" angle catches five of the case bolts which I oversized to 5/16". A couple of struts and one bolt down to the shroud frame holds it all on there.
Old 04-17-2021, 12:45 AM
Its a 42" tiller and from what can find they all use an 8 HP engine. Since I have six extra horses in the harness, I decide to over speed the tine rotation. Most tillers turn 200 to 220 from my research. I'm geared to turn 260 at 3,000 engine rpm and the engine's WOT is 3,500. Theoretically, I should be able to increase my ground speed by about the same percentage. I ran it for a couple of minutes at WOT and it's fairly quiet and balanced. Once all the snow's gone and the ground dries up a bit, I can try it out!
The last pic of the "finished" job won't load
Old 04-17-2021, 06:42 AM
Looks like a interesting project.
Old 04-17-2021, 09:28 AM
poellot poellot is offline
I just restored my 1a. I used nlgi 0 grease with moly. I ordered 6 tubes. I used about 1/2 a tube in the gear box. And 4 tubes in the chain case. I think it was shaffers brand. Seems to be very good grease.
Old 04-17-2021, 10:42 AM
twoton twoton is offline
Great job on the conversion there Ambush!
And thanks for sharing the details. I look forward to the action photos...
Old 05-07-2026, 10:35 PM
Bwoody Bwoody is offline
Hey, I know this is an old thread. Did you ever get this going? I was thinking of doing the same.
Old 05-08-2026, 10:28 AM
Yes, it’s been tilling for five years now, probably about two acres, with multiple passes. I’ve since added an extra tine set on each end and outboard bearings. Also depth shoes. It tills a full 42”. I did a thread on that upgrade and it’s on here some somewhere. The only downside so far is the extra noise and one more motor to maintain.
I also converted it to mount on the sleeve hitch which makes hook up faster and easier.
