Old 05-20-2021, 12:59 PM
mgruber04 mgruber04 is offline
Default Found a replacement battery for Cub Cadet Diesel (782D, 882, 1572, 1772)
I bought a new battery on Amazon -- it was for a Harley Davidson Motorcycle. It is basically the same size as the lawnmower batteries, but it has 600+ CCA and starts the diesel in a couple of cranks. It seems like it is expensive at $150.00 but when I installed it, the tractor fired right up after 30 secs of GP. it makes it well worth it.
model -- MX30L - MOTORCYCLE BATTERY - 600+ CCA
Brand -- THROTTLEX
Price -- $149.99
Free shipping with Prime.
Old 05-20-2021, 03:40 PM
Brand -- THROTTLEX
Price -- $149.99
I would not use that Bat-tree, pert soon yer engine will start vibrating/shaking, and leaking oil.
It will also cause you to want tattoo's, grow long hair and wear a leather jacket while using the tractor.
Also start noticing wimin' in white, that look like Flo---
Old 05-20-2021, 06:34 PM
Please list the dimensions of that battery.
And post a picture of it installed in your Cub.
Is there plenty of clearance for the hood when closed?
Old 05-20-2021, 07:46 PM
Ozcub's Avatar
Ozcub Ozcub is offline
It looks like a sealed battery is it a Gel or Calcium , anything else I was told by a battery supplier will slowly internally shake to pieces on a ride-on due to vibrations
Oz
Old 05-23-2021, 07:16 AM
Default This is an AGM battery.
AGM (Absorbed Glass Mat)
Non Spillable Sealed Technology With Heat Sealed Cover
Dimensions:
L = 6 5/8,
W = 5 3/16,
H = 6 7/8.
Weight = 22.5 lbs
It is basically the same size as a regular lawn mower battery and does fit under the hood closed (has a peek aboo of space to clear on terminals)
I used bungees to strap to base box to save shifting/rattle on batt.
1st pic is hood closed with side panel installed.
second one is battery from above.
third one is closer up terminals view.
