Old 05-26-2021, 04:42 PM
Jim in SC's Avatar
Jim in SC Jim in SC is offline
Default Bought a Cub Cadet 70 today
I've been looking for a 70 for a while - found one on CL this week (pretty good price) and picked it up today - the PO had a roll-over on it a year ago and hasn't touched it since (broke his leg x3 and his hip - no wonder he wanted to sell it!). It looks pretty good - has it's share of rigged stuff on it, which will go away as I get into it. Not sure of it's year yet (SN is painted over) or the engine - the Kohler spec sheet is unreadable so far. Here's a pic of the tractor
1951 Farmall H; 1957 Willys CJ5; 1959 Farmall Cub; 1961 Cub Cadet Original; 1963 & 1964 Cub Cadet 100's; 1971 Cub Cadet 106
Old 05-26-2021, 07:16 PM
twoton twoton is offline
Nice, I'd like to have a 70.
Old 05-27-2021, 10:08 AM
3 point to boot!
Old 05-27-2021, 03:59 PM
Jim in SC's Avatar
3 point to boot!
Yep! One of the reasons I go it!
Hey, a question for the Forum: I know where the serial number is SUPPOSED to be on a CC 70 (on the square raised spot on the right side of the tranny). I removed the paint there and have taken multiple pictures and blow-ups of the bare metal, but see no numbers. I'm thinking about using a weak acid on it to "raise" the numbers, but have read that there is a second place to look on the gear reduction housing. Only problem is I don't know where that place is! Any help would be appreciated! here's a pic of what I have so far:
File Type: jpg IMG_20210527_131943294_BURST000_COVER_TOP.jpg (16.7 KB, 115 views)
Old 05-28-2021, 07:02 AM
I'm not sure but is there a tag on the left side of the rear next to the cover? Nice looking machine too.
What part of SC are you from? Vince O has a plow day over near Greenville once or twice a year.
Old 05-28-2021, 07:41 AM
ironman's Avatar
ironman ironman is offline
Lookie here......
or read here #17 http://cubfaq.com/questions.html
Old 05-28-2021, 07:11 PM
Jim in SC's Avatar
No tag, but I think I found the SN after reading Ironman's post, below.
I'm in Coastal SC, near Myrtle Beach. I'll try and check out the plow day after I get this one up and running - probably not this year though...
Old 05-28-2021, 07:13 PM
Jim in SC's Avatar
Originally Posted by ironman View Post
Lookie here......
Thanks Ironman! Yep, there it was. Now I've got to clean it up a bit tomorrow so I can read it!
Old 05-28-2021, 07:50 PM
Jim in SC's Avatar
Hmmmm. Interesting. Based on what I'm learning here on old posts, looks more and more like my 70 is, in fact, a 100. It has the "remains" of the fancier steering wheel described for a 100. I've yet to be able to read the data plate on the Kohler (it's been painted and scraped - not sure it's readable), but I suspect it may be a 10 HP. Too late tonight to check, but tomorrow for sure. Are there any visible differences between a 7 HP and a 10 HP?
Old 05-28-2021, 08:20 PM
ironman's Avatar
Very big differences.
Although the K161/181 block is similar in construction, assuming everything is still correct, the biggest obvious differences will be the gas tank, the air cleaner, and the muffler, along with size.
Red tractor = Cub 70 (7 h.p.)
Yellow tractor = Cub 105 (10 h.p.)
