How much, if any play is acceptable in the drive shaft for an 1864. I get some play when I grab the drive shaft near the hydro coupling and move it from side to side. Is this normal or a problem? I think it needs to be looked at, but I wanted to check before I tear it apart. Removing the drive shaft is a pain in the butt.
2364i (1541) Kohler ECH23 Power Steering 54" Deck 451 Snow Blower 42" Plow |
Should not move side to side.
Is the shaft moving in the CV joint or is the adapter moving on the pump input shaft? I've seen a few adapters that the splines have worn and you get some movement.
I am pretty sure that the shaft is moving in the CV joint. I will know for sure tomorrow when I take it apart. Hopefully that is the case.
I spent the day working on the drive shaft. Definitely a worn CV joint. Luckily I had the parts laying around. Glad I caught it before it fell apart.
Which parts were worn?
The drive couplings were worn. The drive hub and ball bearings were OK. Now I need to remember to grease the drive shaft more often.
