Old 06-22-2021, 07:53 PM
barns1 barns1 is offline
Default Getting Back Into Cub Cadets - 1450 or 1210?
It's been awhile since I have had a CC due to health issues, feeling some better for the time being and thought it would be nice to get back into a garden tractor to tinker with. Two I have been looking at are a 1450 and a 1210 both hydros. Which is more versatile? Which would you prefer out of the two? Better tractor of the two? Thanks for any assistance you can give.
Sorry, I just realized I placed this in the wrong area. Is there anyway to move it to the correct area?
Old 06-22-2021, 08:50 PM
I'd rather have a 1450. Honestly if I was going a QL I'd really want a dual stick 1650, but going with the criteria you said, I'd go 1450. I prefer those over a 1210. I prefer an IH cub cadet.
Old 06-22-2021, 09:01 PM
Thanks for the information. Which of the IH CC's would you recommend? Can be manual or hydro transmission.
Old 06-22-2021, 10:27 PM
Billy-O's Avatar
Billy-O Billy-O is online now
The IH 1450 would be my choice, too! The 1210 is a MTD.
Plow blade
#2 Cart
QA36 snowthower
Old 06-23-2021, 08:35 AM
It's also only 12 HP and has manual lift
If you want a hydro, Look for a 1450 or 1650 w/dual hydraulics
Gear drive, a 1000 or 1200
Old 06-23-2021, 03:46 PM
Thank you for your advise. I wouldn't mind having a gear drive, thanks for those suggestions also.
Old 06-23-2021, 04:17 PM
Or better yet a 169
Old 06-26-2021, 01:17 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
This whole "it's MTD/CCC built, so it's inferior" is quite laughable. The 1210, and the other 82 series were engineered and designed by IH. There were some mechanical improvements made after the CCC acquisition. To me, the 82 series was the zenith of Cub Cadet tractors in terms of construction, reliability, drivability, appearance, and ease of use. The Cyclops era was a step in the wrong direction with the vast use of plastics, and the styling, but still a very solid machine. Now, after the demise of the Cyclops/82 series chassis in 1997, the "MTD is crap" argument does hold merit, because the designs going forward were made with a focus on cost savings for MTD, and lack of durability and quality for the consumer.
I'd pick the 1210 all day, every day.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 06-26-2021, 03:51 PM
I, for one, am not impressed with the plastic dash panel, what's left of it that is, on my 82 series!!
That model needs a positive flexible hood stop IMHO.
Old 06-26-2021, 05:36 PM
1711Cub's Avatar
Wink
Yes, that is a deficiency. All units with some use will have grooves worn into the plastic from hood contact, and if the unit was outside a lot, the plastic will get brittle and crack. Beyond that, there is little plastic to break.
