Old 06-25-2021, 05:36 PM
thadscub's Avatar
thadscub thadscub is offline
Default Engine cranking when key is off
Okay I have a problem when I go to hook up the battery the starter generator crank when the key is off. I have a new starter relay is a stens along with the new voltage regulator which is new confirmed all wiring is hooked up correctly. where should I start looking for the problem thad
thadscub's Avatar
Default more info
This is a cub cadet 123
Old 06-25-2021, 05:44 PM
Did this problem occur before you did the work??
Did you mess with the starter switch wiring any?
Are you sure the V/R is correct for the application and wired correctly?
IH-545130-R92
Old 06-25-2021, 05:57 PM
thadscub's Avatar
The voltage regulator is Stens 435-040. Listed that part # has 4 terminals. The starter relay is Stens 435-008 3 terminal. The problem started after I changed these, never moved wires on it ignition switch.
Old 06-25-2021, 06:07 PM
Something is NOT wired right or you have the wrong parts.
Old 06-25-2021, 06:23 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Hard to disagree;with the others...... I'm curious to why were you replacing these parts before the problem? Recheck your wiring and do make sure the regulator is properly grounded.
Plow blade
#2 Cart
QA36 snowthower
Old 06-25-2021, 06:41 PM
thadscub's Avatar
Default problem located
Found the problem it was the green wire to voltage/ starter generator when I disconnect the green wire from the starter generator it works with the key switch what would cause that
Old 06-25-2021, 06:59 PM
All "will fit" voltage regulators are NOT created equal.
We get this very same question more than once a month here.
The regulators have to be wired as per their lug identified terminals, not their physical location on the regulator.
Old 06-25-2021, 07:10 PM
thadscub's Avatar
Thats what I did followed label on voltage regulator
Old 06-25-2021, 07:16 PM
That wire is not green, it is blue. It prolly will not be charging the batt tree now that it is disconnected.
A picture of how you wired it would help...
