Old 07-08-2021, 09:23 AM
Butterbean150 Butterbean150 is offline
Default Cub Cadet 104 front PTO assembly
Good Morning fellas. I recently bought my first Cub Cadet. The prevoius owner removed the front PTO assembly. The only thing that is left is the start pulley, but they cut the notched part the clutch sits in when they removed the PTO assembly. I need the complete assembly. I have the actuator assembly but everything past that is missing. I will attach photos so you van see for yourself. If anyone has an assembly they would let go to get this one mowable I would appreciate it. Thanks.
Old 07-08-2021, 09:46 AM
mortten mortten is offline
A picture would help.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 07-08-2021, 10:17 AM
Welcome to OCC......
Place an Ad in the Want Ad section for best results.
Old 07-08-2021, 11:54 AM
ironman's Avatar
ironman ironman is offline
You can usually find everything you will need thru eBay or vendors, but most of the time the asking prices are so obsurd that your best option is to keep an eye out
for someone selling a clunker you can use for parts. Of course, you then end up with two Cubs that you want to restore.
https://www.ebay.com/itm/13358556478...cAAOSwnhlcAehM
https://www.ebay.com/itm/38426348943...4AAOSwynZg5eM2
Old 07-12-2021, 09:41 PM
I wish I could post the pics I have but I don't know how. I can tear apart a steam turbine but I cant get pics to download in the thread.
Old 07-13-2021, 04:54 AM
The part you refer to is commonly called a basket pulley.
Should be easy enough to find one
