i forgot how this goes on. the snap ring and washer go on the outside right? or does it just float on there? couldnt tell by the pictures in my service manual
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
Snap ring and washer go on the outside. How would it function if there was nothing holding it on?
That's what I thought. there was some wear on the inside so I thought I would check
You might want to make sure that the brake fits good on the clutch if that's the case. If it looks like was spinning before, something might have worn out that caused it to do that. Are the 3 tabs on the brake disc worn too?
i guess i didnt really look that close. could i convert the brake system to the old style system?
yes , you can change to old style
