Old 07-14-2021, 10:31 PM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
Default 1450 seat switch
I'm looking to install a "operators presence" seat switch in my 1450 so the engine won't start and will shut off if nobody is sitting in the seat. Basically a seat switch like on the 82 Series. My question is where in the wiring harness would I install the switch? I'm thinking maybe between the I terminal in the Ignition Switch and the + Coil terminal?
Old 07-15-2021, 07:28 AM
You would be correct.
Old 07-15-2021, 10:51 AM
The switch proper would have to be under the seat so as to be operative when someone has their butt in the seat
Old 07-15-2021, 12:56 PM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
Perhaps you could install a weight-detecting sensor that lets the operator know they're getting too fat
Old 07-15-2021, 03:54 PM
Thanks for the replies. I've got Roland's colorized March 2006 wiring diagram which is how I came to think the ignition switch to coil wire was the right place to splice a switch into. Yeah, I know the switch has to go under the seat and it seems the correct switch is the 925-3060. Hopefully I've got one in my box of spare CC parts. I may use the 720-3001 seat spring from my 782 because on that tractor I've already bypassed the switch.
