Old 07-15-2021, 10:59 PM
Mcfall Mcfall is offline
Default Cub 109 not shutting off
Recently purchased, it ran fine but was leaking gas from carb when it set. I got into the habit of turning off the gas when I was done.
I'm not smart enough to leave well enough alone and rebuilt/cleaned carb. While it was off, I replaced the coil and condenser.
Now when used for a prolonged period, the engine won't shut off when the key is turned to the off position. I turned the gas off and it'll eventually stop.
Any ideas on what could cause this?
Thanks
Old 07-15-2021, 11:25 PM
mortten mortten is offline
With a volt meter or test light make sure the black wire going to the positive side of the coil has zero voltage with the key off. May be a bad switch.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 07-16-2021, 08:09 AM
First, welcome to OCC ............
I also suspect the Ignition Switch.
Old 07-16-2021, 08:58 AM
ironman's Avatar
ironman ironman is offline
Thanks
If it does not shut off, power has to be continuing to be provided to the coil, and will be continued to be there even after the motor runs out of gas.
That means at some point, if you do not fix it or disconnect the battery, you will find youself with a dead battery and a burnt-up brand new coil.
Do you have the wire from the ignition switch connected to the Plus side of the coil
Do you have the wire to the points connected to the negative side of the coil?
Do you have the condenser wire on the Negative side of the coil?
You didn't mention, but did you by any chance replace the ignition switch too?
Old 07-16-2021, 10:44 AM
Billy-O's Avatar
Billy-O Billy-O is online now
Agree with others....and looks for bad or crossed connections leading to shorts and/or overheating the electrical components.
Plow blade
#2 Cart
QA36 snowthower
Old 07-17-2021, 12:41 PM
I had time to look at it today, wire going towards switch (+ side of coil) was original and had some play in the connector , I put a new end on it and cleaned the switch posts and connectors.
That appears to have resolved it.
Thanks for the tips!
