Old 08-19-2010, 04:50 PM
GrantC GrantC is offline
Default Front tire sizes
The front tires on my 123 are 16x6.50-8. I'd like to go to a tri-rib design, but all those I've found are significantly narrower, and I'm told won't fit on my rim.
I've owned a Simplicity with 4.8 fronts, and like narrower front tires anyhow. The main question: can narrower rims can be found for the CC?
-=[ Grant ]=-
Old 08-19-2010, 05:36 PM
Merk Merk is offline
Your rims are too wide. You will need to change to a narrow rim to run 3.5-4.0/8 tire.
Old 08-19-2010, 06:55 PM
ihc353s's Avatar
ihc353s ihc353s is offline
Hi,
i use a Set of 3 Ribs in Size 16 x 6.50 x 8, The Tires are from Miller Tire, and the Brand of it is Firestone.
mfg Georg
I'm proud to be a German Cub Cadet 782 Owner!!!!
Old 08-19-2010, 07:47 PM
Are there narrower rims available?
-=[ Grant ]=-
Old 08-19-2010, 07:48 PM
Originally Posted by ihc353s View Post
Hi,
Thanks - I'll look for those!
-=[ Grant ]=-
Old 08-19-2010, 09:29 PM
Not to dispute Georg or start any arguments, but I have heard a lot of bad things about those Firestone tri-rib tires. People have mentioned that they weather check in less than a year in some cases with very little sun exposure. I don't think they are actually made by Firestone but in Vietnam by a company that bought some molds from Firestone. Sounds to me like they didn't get the rubber compound quite right. I decided to buy these Vredestein V61 tires instead for my 782D, and so far I think they're wonderful. Everyone I know that has them loves them.
Old 08-19-2010, 10:26 PM
GrantC,
Yes, there are narrow rims available out there. In fact, some of the models came stock with those rims, like the originals, the 70's (I have a model 73 with the narrow rims). I also have narrow tri-rib tires on narrow rims on my 123 and really like the looks & performance of them!! If you are cutting grass, the narrow tri ribs don't compact the grass before the blades get to it, causing uneven stripes, like the wider front tires do. They also make narrow ag tires for the fronts --I just purchased a set this summer by Carlisle. I have seen a cheap set of narrow tri-ribs go for about $24/pair and a higher quality set for about $50/pair. Sometimes, you can find a reconditioned set of rims, already painted up, with a brand new set of tires already mounted on them for about $100. Hope this helps you out some.
