Old 07-24-2021, 10:30 AM
Default 127 Tiller Model?
Morning Folks. Looking at this 127, several hundred miles away but
pretty darn close by MT standards. While it looks quite tempting, one of
the main reasons to have it would be to use the plow, and unfortunately
a tiller which he does not have.
First off, what tiller fits this tractor? #1, #2 ? I would not want to
look for the wrong one.
Secondly, do you all in the world where Cub stuff exists even see these
tillers around. Would hate to bring this home and never be able to find a
tiller. Hope you all are well, Thankshttps://kalispell.craigslist.org/grd/d/kalispell-international-cub-cadet-with/7342628409.html
Ken
Old 07-24-2021, 10:33 AM
Not sure that link was good on last post. Here is another try.
https://kalispell.craigslist.org/grd...342628409.html
Ken
Old 07-24-2021, 12:03 PM
Both #1 and #2 will work on that tractor with the correct mule drive and belt.
Make sure to get the gear box, mount and belt guard if you find one.
The @1 tiller may have 1 extension (left or right side) or both (left and right side) essentially making it the same with as a #2 which is 42"
The #2 tiller is 42" and has no extensions.
Looks like a decent unit including the 3 point, sleeve hitch set-up and plow mot to mention the other items included.
If you plan on using the plow much, better plan on at least a set of chains and some weight or better yet a pair of ag tires and some weight.
Good luck!
Old 07-24-2021, 09:09 PM
Thanks for the info. I will look for the tiller first and then see if the
127 is still around. Would that be putting the cart before the horse?
Ken
