Old 08-18-2021, 08:40 AM
JTsch JTsch is offline
Default Tiller Chain
Originally Posted by RedHawCadet View Post
So pulled the whole dang thing apart today. The chain was broke and had multiple other splits at the ends of the links just waiting to let loose. I cleaned it all out in the solvent tank and put a new chain on. Everything else looked to be workable. I'm going to put her back in the ground tommorow! Thanks for all the replies!
If its ok to resurrect an old thread, where did you find the replacement chain? I'm looking like I have the same issue of a broken main chain (brother hit a tree root) but I'm not having much luck finding one online.
-jt
Old 08-18-2021, 09:08 AM
First, welcome to OCC...........
The OEM Chain(s) are NLA.
This chart should help you. Chain like this can be had at a local Farm Dealer or Ag type of store. McMaster-Carr also carries this.
Old 09-16-2021, 03:33 PM
coakes00's Avatar
coakes00 coakes00 is offline
If you take it into your farm store they should help you match it up. It might get a little pricey because they usually only sell it in a box of 10ft about $30-60. If it's a #2 tiller, it uses #50 for top chain and #60 roller chain for the bottom so that's 2 boxes to buy.
Old 09-16-2021, 04:33 PM
Not as bad as all that.
Here's what mine cost 4 years ago
Tried to post a copy of the invoice to no avail
Case/IH dealer
$36.20 plus tax for both plus the connector links
Old 09-17-2021, 09:16 AM
Try McMaster Carr
https://www.mcmaster.com/roller-chain/
