Old 08-19-2021, 04:44 PM
New_England New_England is offline
Default Generator pulley nut
Hello,
I bought a new generator and when putting the pulley on I used an impact driver to tighten the pulley nut. As you can guess I over tightened it and pushed what I believe is the bearing down the shaft so the pully now rubs the generator.
Can this be remedied or is the generator trashed.
Thanks!
Old 08-19-2021, 04:55 PM
You prolly forgot to put the spacer on the shaft before you put the pulley on and tightened it up
Old 08-19-2021, 05:23 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Or maybe the pulley on backwards.... it may have an offset.
Plow blade
#2 Cart
QA36 snowthower
Old 08-19-2021, 06:29 PM
DSarow DSarow is offline
I would look up on the parts diagram to see if indeed there was a washer. Investigate which way the pulley, goes by paint, dirt or, only fits one way, or look at another tractor. My memory is getting such I take a picture, or mark the part. We all do it. I think you should be able to save it. Easy on the torque. Good luck, hope it works out for you.
