Old 08-26-2021, 04:12 PM
Default 1872/2072 Owners
What is the Negative Battery Cable grounding path on these models? Is is simply from the negative terminal to the frame?
Old 08-27-2021, 07:36 AM
That's how it was on my 1210. Run a ground from the Battery to the engine block or starter mount and be happy.
Old 08-27-2021, 07:47 AM
Sam:
I wasn't for sure on how the grounding was done on those SGT's.
That is what I was thinking. I done that to my 1450 and 784. Never had a "roll over" issue.
Old 08-27-2021, 10:18 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
On my 782, 1711, 1811 the only ground located on the tractor is the battery to frame ground. On my 1050, there is another ground wire from the frame to engine block, since they have the iso-mounts. My other tractors just have the steel spacers directly mounted to the engine pan to the frame.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 08-29-2021, 02:48 PM
Bsmith Bsmith is offline
On 2 2072’s and 1 1872 that I’ve had my hands on, it was just battery to frame. Negative battery cable was about 10” at the most.
Old 09-01-2021, 12:17 PM
Mcamp Mcamp is offline
there is also a small ground wire from in the harness that goes onto one of the engine side tin bolts above the starter.
