Old 09-07-2021, 06:57 PM
thejed72 thejed72 is offline
Default Cub Cadet Original throttle parts/setup help needed
Ok guys, need a little assistance with the throttle. I have a new cable, carb is rebuilt but untested, new sediment bowl, but I had a green zip tie holding the throttle wide open when I purchased the tractor. Throttle cable disconnected. Missing whatever springs should be there, and no choke cable. I can't find any decent pics of the throttle cable setup and any springs, brackets, or anything else needed to make the throttle work properly. I do have a rigid link between the throttle arm (for lack of the correct part name) and carb. Pretty sure that's correct. I do have a choke cable that came with, but it's semi seized and currently soaking in WD-40 to start. No idea how that works either. Any pics you could share would be helpful to know what I'm looking at and for. In the mean time I'll check out the service manual to see what I can figure out.
Old 09-08-2021, 10:30 AM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
From the Operators and Service manuals...
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
Old 09-09-2021, 09:12 PM
Thank you very much!
