Old 09-10-2021, 10:43 AM
glennjr glennjr is offline
Default Fuel for older K241 engines.
Should I be using a "lead" substitute in the older K series Kohler engines ?
Old 09-10-2021, 01:20 PM
My view is no need.
Lead was used for valve lubrication and to prevent spark knock.
Not a lot of valve seat recession is experienced in those small engines, and the cast iron used is of good quality so it is minimal, unlike some vehicle engines of years past.
And as far as knock from high compression, those engines are around 6.5 to 7 to 1 Compression ratio and knock occurs near 9.5- 10 to 1 or so.
They are a long ways from that compression.
Now if one is running a modified engine with high compression/ increased valve lift, & heavy springs, that is a different story.
I am assuming you don't have a performance engine.
Best thing for longevity is keep the oil changed/clean and give it a few minutes to warm up before working it WFO throttle.
