Old 09-12-2021, 09:24 AM
Marko141's Avatar
Marko141 Marko141 is offline
Default Narrow rims on a 1450?
I understand I can’t pull narrow rims from a narrow frame and put them on a wide wide, are there any options for the wide frame cubes?
Cub Cadet 127, 1450, read bottom plow, blower, tiller, wheel weights, chains
Old 09-12-2021, 10:19 AM
dale c. dale c. is offline
the narrow frame wheels will fit on wide frame also
Old 09-12-2021, 02:48 PM
cubby102's Avatar
cubby102 cubby102 is offline
They will go right on as long as your 1450 had the 3/4 spindles. If its a later machine with 1" spindles im not aware of any narrow wheels to fit
Old 09-12-2021, 06:47 PM
Bingo, I agree.
Old 09-12-2021, 07:21 PM
Marko141's Avatar
Mine have the 1”, thanks for clearing that up.
Old 09-12-2021, 07:22 PM
Marko141's Avatar
Think the bearings could be swapped out for larger ID to fit the 1” or?
Old 09-16-2021, 06:48 AM
machinist can cut the hubs out and install larger to fit 1" bearings.
Old 09-16-2021, 09:36 AM
I doubt if there is enough "meat" for that.
One would have to remove and install a larger hub center for that to work.
Just get a pair of 3/4" knuckles and use them.
Lots of those around, I'm sure!
Easy Peasy!!
Old 09-16-2021, 05:05 PM
IHinIN IHinIN is offline
You could also narrow your wheels. I have 1” spindles on my 129 and I narrowed my wheels to 4.25” by cutting a section out of the wheels and welding them back together. To me, the 16/6.5/8 Firestone 3-ribs looked too narrow on the 5.38” wide wheels. The wheel actually stuck out past the sidewall before.
