Old 10-03-2021, 09:55 AM
davew davew is offline
Default 1450 electric PTO
how can i tell which front electric pto my 1450 uses? it set for 10 years and the pto had been removed when i bought it and the owner didn't remember removing it, let alone what kind it was. i see there are 2 possibilities but the only identification method mentioned "is it black or silver".
Old 10-03-2021, 10:04 AM
The "black & silver" differentiate the Vendors of the part. They mount and operate the same. The black one is the most popular.
Old 10-03-2021, 11:20 AM
does a new clutch come with everything needed to install or will i need to find a pulley and or possibly brackets and special hardware? i have standard bolt and nut bins so that is not a problem but i have only messed with the mechanical pto systems before. never seen the electric set up.
Old 10-03-2021, 07:44 PM
Workingstiff Workingstiff is offline
I went with the xtreme pto clutch, it was a few bucks more. Time will tell if its worth it. Xtreme uses a redesigned model. More plug and play.
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 10-04-2021, 02:42 PM
You make NO mention of what was left behind. So, it is hard to say what you need. As speculation, I am thinking you may need some nuts, and springs. Can't say without seeing some pictures.
