Old 10-05-2021, 09:17 PM
lma20 lma20 is offline
Default New to Cub Cadet. Bagging is awful. Any ideas?
First time Cub Cadet owner. I have used Toro, Yard Machines, and Craftsman. I have to say, this one bags the worst. It seems only about 50% of grass is actually bagged (yes, I'm using the high lift blades). The rest seems to be blown out the bottom, and off that, a lot end up on top of the deck, and the rider.
The Craftsman, which is what I owned before this, had a baffle, but the CC does not.
I'm assuming this is a design flaw. Do you all have ideas how to improve this?
Thx in advance.
Old 10-05-2021, 10:21 PM
Billy-O's Avatar
Billy-O Billy-O is offline
What model tractor and what make/model bagging system is giving you this problem?
Plow blade
#2 Cart
QA36 snowthower
Old 10-06-2021, 09:10 AM
model: 13APA9CT056
bagger: https://www.homedepot.com/p/Cub-Cade...oduct-overview
and I should've been more descriptive. It's no just bagging, its mowing too. A large part of the grass shoots under the deck gets everwhere, including mower deck. It bothers me most when I'm trying to bag since just moving grass to the right really isn't what I'm looking for.
Old 10-06-2021, 09:24 AM
The model is: XT1-LT46
Old 10-06-2021, 11:23 AM
ejl6658 ejl6658 is offline
Are you operating the mower at full throttle while mowing? That is necessary to have high rpms on the mower deck especially when bagging.
Old 10-06-2021, 11:45 AM
Yes. plus enough characters to post.
Brand new machine?
Has the deck been properly leveled and adjusted correctly from front to rear?
Old 10-06-2021, 12:02 PM
cooperino's Avatar
Are all the blades on correctly? The deck on that is molded so no baffles needed. It is a high lift deck assuming it has the deck that came with it of course. I had one many years ago and it bagged great. Tall grass, leaves etc were never an issue bagging.
Old 10-06-2021, 02:50 PM
Billy-O's Avatar
Here is some helpful hints: https://www.lawnmowerfixed.com/grass...oubleshooting/
At this time of the year with the weather cooling down the grass will tend to be damp, thus contributing to the problem. I would look for blockage and make sure the bags aren't clogged.
Plow blade
#2 Cart
QA36 snowthower
Old 10-06-2021, 05:33 PM
Merk Merk is offline
Is there some type of blower unit between the bagger system and the mower deck?
You will need a blower system for it to work right. As stated in earlier post the grass is wet and heavy. You will need a good exhaust vent for the system to work right.
I have a system something like this:
https://trac-vac.com/
www.cyclonerake.com
Project Uncle Dick
Cub Cadet 70
