Old 10-07-2021, 10:13 AM
Chevyguy Chevyguy is offline
Default Predator engine swap
Has anybody swapped a Predator engine into an 82 series Cub Cadet? I'm considering replacing the Briggs in my 582 and was wondering if the Predator would be a good candidate with minimal or no modifications needed.
Old 10-07-2021, 10:19 AM
Gompers Gompers is offline
I haven't done it personally, but they've been done and they work well. Exhaust/PTO/driveshaft is always the tricky part. I believe you can (or used to be able to) get an adapter for the flywheel/driveshaft part that fits a honda engine and work from there.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 10-07-2021, 06:34 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
Horizontal shaft engine? I'm not familiar with the 582.
I think the biggest thing people run into is the charging system on the predator sucks.
If it was me I'd find an 18 or 20hp kohler out of a 2000 series.
Not only is it a better engine but will likely bolt right in.
JD x475
Old 10-08-2021, 09:47 AM
Try these guys for adapters
https://www.performance670.com/?fbcl...gCHqQZCg3H4uJ8
Old 10-13-2021, 12:40 PM
Thanks for the advice!
Old 06-25-2023, 09:27 AM
AGuyThatUsesOldTractors AGuyThatUsesOldTractors is offline
I just did it on a 682 so it's fresh in my memory. Here's what I had to do to give you an idea of what's involved. In my case, I tried to keep the 682' as unmolested as possible in case I or someone would want to put an original motor in it some day.
The two repower sites that I inquired with no longer sell just parts without a motor. It's all or nothing, so I had to make just about everything.
The two things I did buy was the engine mount plate from Performance670 and a 1" - 1 1/8" sleeve for the PTO
The engine mount plate (1/4") + the KT17's original engine spacers (1/2") gave the engine the perfect height. I welded the spacers to the plate.
I had to make my own extension/coupling for the driveshaft to connect to the flywheel. Performance670 may've had something that would've worked but they said it would need to be modified so I didn't bother with theirs. I tinker around with aluminum investment casting so it was an opportunity to put that use.
I made an adapter plate to adapt the PTO bolt pattern to the engine's bolt pattern.
I modified the Predators muffler to have a front exit instead of the side exit.
Since the 682 originally had a coil ignition, I wired in a relay to connect the 670's ignition coils to ground when the key is off.
I removed the needle from the carb's fuel cut solenoid and left that disconnected. I wanted to leave the fuel cut solenoid functionality in place, but since the 682's ignition switch cuts the 12v line during cranking, I would've had to do extra wiring with diodes or relays so some such thing that I didn't want to try and work out right now.
I did connect the oil level sensor to the ignition coils so the low-oil ignition cut function should still work.
I used the CC's starter relay and just ran a heavy wire extension from the original starter wire, which is on the left side of the Kohler to the 670 starter, which is on the right side.
I was able to mount the CC's choke cable onto the engine without any major modification. For the throttle, I connected the CC's throttle cable to the 670's with the little barrel/screw connector that came on the 670. I welded a n extra bracket onto the 670's alternator bracket to hold them in place. It's a little extra complication but again, I wanted to modify the 682 as little as possible.
I think that is about it for the major hurdles. The one oil line to the cooler rubs a little on the side cover when it's in place so I would be concerned with it wearing through after many many hours of use. I think by shifting the oil cooler position a little I can alleviate that.
Impressions?
It runs nice and smooth and is quite a bit quieter than the CC's I have with the M18.
Power? It's got good power, but the CC's I use with the M18 don't seem to struggle with much either so I don't know how noticeable the extra HP will be in practical use.
The charging system, as is known, is weak. With the PTO on, it seems to hold its own when it's at or near full throttle (according to the ammeter) But I'll know better after some mowing sessions whether or not it's going to be able to maintain the battery charge. With the headlights on, the ammeter reads discharge Of all the obstacles, this is the most annoying as there are no simple fixes.
I've read a couple different options: belt-driven alternator (it'd be quite hard to make that fit I think), 6-magnet flywheel from a Honda (timing keyway is in a different place so would have to be modified), or the most intriguing solution, rewind the charging coils with more windings to increase their output.
Old 06-25-2023, 02:44 PM
cooperino's Avatar
I have thought about weak charging system on different tractors at different times for one reason or another. I thought a few times, maybe I can add a capacitor in line with battery. I have not looked into what proper size cap it should be. I got to thinking about this after seeing several car audio guys adding large capacitors for sub bass speakers demaning more power especially when car is at an idle. Anyway, something I might look into
Old 06-29-2023, 06:16 AM
A large cap is only for supplying high current during very short periods, such as when starting up an electric motor from a dead stop or when someone feels the need to vibrate all the windows in a 200 ft radius with a bass hit from their car stereo. It's not really going to provide a net benefit to a weak charging system on a lawn tractor.
If you're curious how the Predator fits into the CC, here's a pic (this forum has really strict attachment limitations!)
Old 06-29-2023, 06:17 AM
Here's the picture
Old 07-03-2023, 08:27 AM
Rex B Rex B is offline
"With the headlights on, the ammeter reads discharge. Of all the obstacles, this is the most annoying as there are no simple fixes."
How about switching to LED headlights?
