Old 10-31-2021, 10:05 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Default Small engine fuel strategy
I've heard it said that "95% of small engine failure to run problems are fuel problems". In my humble experience that's right (the next 4% can be fixed with a quick clean of the points, and everything else fits in the remaining 1%).
My new philosophy when I'm not going to be using an engine (other than my diesel) is to turn the fuel valve off, then run the bowl dry. At "end of season" I'll drain the tank too.
Anyone see any downside to this strategy? I am sure I'd end up spending less time doing this, than in replacing/rebuilding/cleaning fuel systems corrupted by old gasoline sitting for months.
Even with the economic policy of the current regime, gas is cheaper than carburetors.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 10-31-2021, 10:49 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Either that or run the engines once in a while during off season.
Plow blade
#2 Cart
QA36 snowthower
Old 10-31-2021, 12:00 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
I like to start them up once or twice during the winter and let them run for 20 mins. Also, if you can buy it in your area, go with the non-ethanol fuel.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 10-31-2021, 01:46 PM
TheSaturnV's Avatar
Non-ethanol strategy here. Not sure what your local climate is but an empty fuel tank can potentially condensate.
Old 10-31-2021, 02:39 PM
jbrewer's Avatar
That's a good point. I use 100% gas too.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 10-31-2021, 05:08 PM
CubDieselFan's Avatar
I use 100% gas. Do not drain anything.
Old 10-31-2021, 07:06 PM
I use "Rec 90" (no ethanol). I don't drain or run dry anything.
Old 10-31-2021, 09:15 PM
aagitch's Avatar
aagitch aagitch is offline
Non-ethanol here too.
Adrian
2072 (789513)
Old 10-31-2021, 11:25 PM
Most of my smaller engines like lawn mowers , weed whackers etc. I run
dry. Especially 2 cycle stuff. My cubs I try to run occasionally through the
winter. For the most part they sit in the unheated side of the shop. I pull
the batteries. I too think a bit about condensation. Usually don't leave
the metal tanks empty. Run the expensive er gas here, it's worth it.
Ken
Old 11-01-2021, 08:00 AM
Cubcadet_107's Avatar
Cubcadet_107 Cubcadet_107 is offline
Rather than deal with running stuff dry and/or draining tanks, I go the route of running stuff throughout the winter. Granted most of my equipment doesn't ever really go into any sort of storage over winter, other than the push mowers and all the little antique small engines I've managed to collect.
'70 107 with k301 engine swap
'71 106 with 38" deck
'70 147R with factory replacement k321, 42" deck
'61 Original with 38" timed deck
'63 70 "pinkie"
1863 with 54" deck
'46 Farmall H, '50 Farmall Cub
105 x2 (parts)
