Old 11-20-2021, 10:41 AM
Farmall450's Avatar
Default GT54 Mower Deck
I'd like to find a GT 54 for my 2182 (GT 48 just seems a little too small). I don't really love the Habans, tho I might throw one my brother had for his project super on for sh*ts n giggles.
I assume that same deck will bolt right up to a 2182, probably same mule drive (as the GT 48)?
Old 11-20-2021, 01:28 PM
SS5150's Avatar
SS5150 SS5150 is offline
I might be able to hook you up. I offered mine to my cousin for his 2182 but he doesn't seem interested. It needs the 4 roller wheels and it's patched in the LF corner.
It's at my Cousin's in Richmond right now, on my 1861. I think it's going to be a parts casualty.
We could use a good Haban set up for his 2182 if you have any of that stuff. His 2182 is an early build with the IH rockshaft setup.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 11-27-2021, 09:26 PM
Farmall450's Avatar
The Haban isn't mine, so I can't part with that. Interested in yours, however. My 2182 rings in as a 1992.
