Old 11-28-2021, 10:41 PM
Farmall450's Avatar
Default 1811 Mower Decks
Question on decks -- my 1811 came with a 46 GT. Cream, resembles A/C series decks, 3 blade. My 2182 came with a 48 GT deck. Yellow, much taller/thicker, has the step/straps for the 4 corner anti-scalp wheels. Are these the same series or is there some common differential for the substantial difference in scale?
Ideally I'd find a 54 GT (190-324-100) for the 2182, and hand me down the 48 GT to the 1811 or something, as I find myself with a lot of decks that don't mow any grass. It seems the super can still be useful and not get cumbersome with a deck, whereas I don't really need them on anything else.
Thanks.
Old 11-29-2021, 07:47 AM
These are the Mower Decks that were designed for the 1811.
336 46" Mower Garden Tractor 190-336-100 GT
357 38" Mower 190-357-100
358 44C 44" Mower 190-358-100
359 50C 50" Mower Garden Tractor 190-359-100 GT
These are the Mower Decks designed for the 2182.
324 54" Mower 190-324-100
332 46" Mower Adapter 190-332-100
336 46" Mower Super Garden Tractor 190-336-100 SGT
359 50C 50" Mower Super Garden Tractor 190-359-100 SGT
361 50" Mower Adapter 190-361-100
374 60" Mower 190-374-100
The GT46 & GT48 are model numbers, and are NOT necessarily from the same Generation, of Mower Decks.
Old 11-29-2021, 11:51 AM
Farmall450's Avatar
Do you have a generalized name or something to distinguish from the older GT to SGT or newer GT decks?
Old 11-29-2021, 11:56 AM
GT Mower Decks "may" fit on a SGT Tractor, provided there is a appropriate Mule Drive (Adapter Pkg) to do so. Not any GT deck will fit on a SGT.
SGT Mower Decks will NOT fit on a regular GT tractor.
Old 11-29-2021, 05:45 PM
This may help with deck fitment.
https://www.onlycubcadets.net/forum/...399#post513399
Old 11-30-2021, 04:10 PM
Farmall450's Avatar
Thanks guys.
