Old 08-21-2010, 08:15 PM
tservice tservice is offline
Default 127 Service Manual
i am looking for a downloadable service manual for my 127. Cant seen to find it in the technical library.
Old 08-21-2010, 11:01 PM
dyt4000's Avatar
dyt4000 dyt4000 is offline
http://ccmanuals.info/pdf/1x6-7%20Service%20Manual.pdf
Co-Founder
You only need two things in life...duct tape and WD-40
If it's stuck and needs loosening, use the WD-40.
If it's loose and it's suppose to be stuck, use the duct tape.
Old 08-22-2010, 09:32 AM
Thank you so much!!!!
Old 05-05-2011, 09:06 AM
snickle1 snickle1 is offline
Default servicing the Hydro on 127
Dob't find any info in manual on servicing the rear part of 127. I see a filter under there. Should oil be changed, etc?
Old 05-05-2011, 09:12 AM
The oil and filter should be changed. Use Hy-Tran fluid from either your Cub dealer or from a Case/IH dealer. No other type of fluid is recommended or used. You remove the rear end cover to drain the fluid and also use some carb or brake fluid to clean out the inside. Once cleaned out replace the cover with a new gasket and refill with 2 gallons of Hy-Tran fluid.
Link for Filter numbers:
http://www.onlycubcadets.net/forum/showthread.php?t=12
