Hello fellow Cub Cadet enthusiasts! I have a cub cadet 127 I purchased at auction a couple of months ago. Up until today, it ran fine and the speed control lever acted normally. Now when I move the lever, I can see the linkage moving but I don't feel the same engaging resistance I felt before and it does not shift into forward or reverse. Any thoughts on why this might happen? I thought I would ask before I start taking it apart.
First, welcome to OCC.........
![]() Two things I would look at. (1) Look under the Tunnel Cover and make sure all you linkages are connected and move correctly. (2) It is a common problem, that the "spirol pin" on the Coupler to the Hydrostat Transmission breaks, then you have nothing. Look closely to see if the "input" shaft of the hydrostat, turns or revolves at the same speed as the drive shaft.
The tunnel cover on the 127 is attached to the frame. Makes it tough to work on.
Richard 1979 IH Cub Cadet 782 w/CH20, dual hydraulics, power steering and Cat 0 three point |
I removed the cover and sure enough the pin is gone. Based on what I am reading this is a 1/4 coiled pin correct? Will a grade 5 bolt and lock nut work as well?
A bolt would work to get you to the garage, but please install the correct style part, it was engineered that way for a reason.
And to answer your unasked question of why:
A bolt, as stated, will get you going but has to much clearance, so the firing engine impulses, tends to work at increasing that clearance over time. Eventually, yall done got a wallered out hole ![]() So they put in a Coiled pin, -----not to be confused with a roll pin. If the hole is already wallowed out, then components need to be replaced.
Thanks for all the info. One last detail, can someone tell me the length of the coiled pin?
According to the Parts Listing, it is 1-1/4".
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
They are not removable on the narrow frames like they are on the wide frames.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart ![]() ![]() ![]() ![]() ![]()
