Tis the season. I have a cylops 1863 the only blower I have available now is my QA blower, will it mount up and work properly?
The QA36/42B Snowthrower should mount right up.
It'll fit, but it probably won't be geared quite right (assuming your cyclops has the newer, smaller diameter PTO).
Probably not a huge concern, but performance will decrease.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
The QAxxA/B were NOT designed for the Cyclops Series Tractors.
Do you know the diameter of the smaller pto pully? I would like to measure mine.
Yes I agree it is not designed for the cyclops, for now until I get my other blower I hope I can manage to get it going anyway I love a challenge. After all I one had it nstalled on my mtd husky.
Yes, you can use it on a cyclops.
1992 2182 with 48" deck, Kwik-Way loader, and QA42A Snow Thrower 2008 RZT 54 |
I was thinking that the later cyclops had a bigger diameter pto pulley
Adrian 2072 (789513) |
1863's have the 6" PTO. My guess is that you will need to put a larger pulley on the blower or you will over speed it.
Thanks Sam Il'l look into that thought, I have to add though on my 1811 it seemed to be slow so maybe a little more speed is what it needs? Lol I wonder what rpm its rated for?
