Old 01-08-2022, 05:30 PM
A-BOMB A-BOMB is offline
Default 782 Trans problems
Hi guys.
Red 782.
I was plowing yesterday and the directional control started acting weird. Within 5 minutes I completely lost reverse.....and only have a little bit of forward. Fluid level good. Filter is good. Lift and power angle act fine.
Today I messed with the pressure caps a bit and the machine got CRAZY. now it's like all forward or all reverse......all out!!! I can't even start it cause it gets NUTS!! Sound familiar to anyone? Can you guys send me a diagram of the linkage as it goes into the Trans? Next weekend I'm gonna pull the fenders and try to figure this out...any help would be awesome.
THANKS.
ANDY
Old 01-08-2022, 08:11 PM
BEFORE you do anything, copy down the chassis serial number, so you get the right diagram. Then click on the tab at the top of the page that says "Cub Cadet Parts and service look-up". Plug in 782, and check the sub menus for the parts you are looking for, within your serial number range.
Old 01-09-2022, 08:48 AM
Thank you!
Old 01-13-2022, 07:18 AM
dale c. dale c. is offline
sounds like the trunnion springs fell out.
Old 01-15-2022, 10:20 AM
Trunnion spring is gone
Old 01-15-2022, 12:16 PM
Bush fix....
Everything fell out of the "window" cause the one side had broken off. I found the two springs on the side of the driveway....couldn't find the washers. I ended up using two nickels as the end caps! Had to sand on the belt sander a touch for a perfect fit. I welded a closure piece onto the window....BAM. it is better than before. Thanks for the help cub cadet people.
