Hi all,
Just wondering what the lift capacity of an original is before the axles snap or something worse. Not looking to stress my original, however, I still use mine for work and it lifts up and down heavy implements. What would you suggest the recommended weight capacity should end at? Edit: I'm so sorry, didn't realize I posted this to the welcome page
I know that the originals don't have a 3pt, but in general cat0 3pt is 500lbs max. The final drives on the IH designed cub cadets are so overbuilt that you would flip the tractor or break the hitch before you break the axle.
https://countryfamilyhomestead.com/d...point-hitches/
Mark from Minnesota 3165 with CC Snow Blower, Front blade, Sims Cab 3185 with 3pt hitch, it runs now. But not well. 48in and 52in mower decks 2185 with mower from my dad when I have a project for it. Massey Ferguson Model 70 corn planter. CC yard cart |
IIRR the originals had bushings at the axle ends, not bearings, so excess weight will just wear them quicker
![]() "Heavy implements" has no defined weight. "Heavy" as compared to what? If you use common sense, no damage will occur. Some liquid fill their tires as well as add wheel weights, but that adds no weight being carried on the frame/axle, but if hung on the rear housing in any fashion then it is carried on the axle. |
If I"m wrong in that, then my apologies.
Might have been an optional accessory. Parts for three point hitch and draw bar are listed in the "Cub Cadet Parts and Service Look-up" link above.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
