Old 01-21-2022, 10:40 AM
ChristopherCT ChristopherCT is offline
Default I bought an IH260a TLB
Hey All,
This may be the dumbest thing I've done in a while. It all happened because I found a perfectly good cast iron frying pan on the sidewalks of NYC a few years back. Then after a long search, I found some rural acreage in Connecticut to go with the frying pan. Then I quickly found our '72 #129 to mow it and trailer stuff around.
But then I became fascinated with hydraulics after the 129, and after I tuned up a friend's forklift. So I though I would buy an old log splitter to satisfy this curiosity. But after narrowly missing out on the almost free purchase of a little Laymor TLB, I thought a TLB might be a great fit for the property and my curious brain. It turns out that small used TLBs, like Kubota's, Deere's and Terramites are very expensive machines. A larger machine- especially a neglected one- can be had pretty cheap. And so...
I'm not going to do much with it until the ground thaws, but here it is. I bet that some of you will see the potential that I do. And if this post needs to be moved, or if you think I need to start barking at another website, I am open to suggestions. By late summer, this machine will be white and yellow again, and most of the decals are still available. Cheers! -Christopher
Old 01-22-2022, 07:26 PM
Workingstiff Workingstiff is offline
What does TLB mean?
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 01-22-2022, 08:00 PM
ironman's Avatar
ironman ironman is offline
It means what's in the middle, the front, and the back.
Old 01-22-2022, 09:17 PM
MSS7120's Avatar
MSS7120 MSS7120 is offline
TLB = tractor, loader, back hoe
Mark from Minnesota
3165 with CC Snow Blower, Front blade, Sims Cab
3185 with 3pt hitch, it runs now. But not well.
48in and 52in mower decks
2185 with mower from my dad when I have a project for it.
Massey Ferguson Model 70 corn planter.
CC yard cart
Old 01-22-2022, 09:30 PM
Thanks, we just call those back hoes
'76 1200 Dad bought
Old 01-23-2022, 08:57 AM
Your reply is very funny, and truthful!
Old 01-23-2022, 09:00 AM
I get that, and I did too. But the backhoe on this machine DOES release with two large nuts, two pins and some hose reconnecting. So then it would just be a "Loader", or maybe just a tractor to some people.
Old 01-23-2022, 09:53 AM
Farmall450's Avatar
Nice machine. Good luck tuning it up. Take care of her mechanically before you bother with the paint.
Old 01-23-2022, 02:39 PM
Fix all the hyd leaks, that will include a lot of cyl seals and replace all suspect hoses.
Then it will run a long long time with no problems.
It is a tool with battle scars, enjoy it that way.
Fix it all purdy, and you will cringe when you use it for anything,---- not good!
Old 01-24-2022, 08:24 AM
ironman's Avatar
Unless it's lunchtime, then it's a BLT.
