I've got a 1872, when its cold, after starting it it won't move or steer. If I let it run for a while and then shut it off and let it absorb the heat it will come out of it but it takes a few times. The colder it is the worse it is. Relief valve issue? What other possibilities? How do I check?
Are you using HyTran Hydraulic Fluid ??
Or is there water in the rear?
Yes I do use the HyTran as did the p.o.
I cant guarantee it but I have not seen milky oil on the dip stick
Or the filter needs a change, may have water in it
I'd pull the rear cover for a good flush and refill.
Ok I see what everybody is thinking, It looks like i'll be flushing the hydraulic pump. Is there a write up on the procedure? I am not able to do a search for some reason.
No need to flush the pump. Get a new rear cover gasket, 2 gallons of your favorite oil and an oil filter.Then just pull the rear cover, jack the front of the machine up and spray the inside of the rear with some brake cleaner. Make sure nothing is in there that shouldn't be and that the suction tube is free and clear of any debris. Good luck and let us know how works after you change the fluid.
Make sure to use the correct filter.
