Old 01-24-2022, 10:41 AM
Default 125 Gas tank
Does anybody know what was the original way that the outlet of the
gas tank was kept from leaking. Working on this one and as you can see
it has been fixed about 5 different ways over the years, from others not
myself. I could not tell from the parts diagram what it was initially.
Might just come up with my own solution anyway, but ya never know.
Old 01-24-2022, 10:52 AM
The 1/8" female bungs are soldered to the bottom of the tank.
You may have to remove it, clean and tin the surface and re-solder it properly to get it to stop leaking.
To be on the safe side, I'd use a new close nipple to attach the sediment bowl as the original threads may be compromised from over tightening.
Old 01-24-2022, 11:29 AM
Some bungs were spot welded first, then sweat soldered to seal.
Clean well and use cut muriatic acid to clean under the mating surfaces, so you get a good, sweated joint, not a mudded-on glob of chit.
Best to use a large soldering copper (if you have one)rather than overheat/burn it using a propane torch.
Remove the close nipple or it will solder itself to the bung.
Then chase the threads in the bung with a pipe tap.
If the threads are already oversize in the bung, let the solder wick up in the threads, then chase them, as it will restore the size of the bung, but be careful that you don't go too big again.
A new close nipple should start, and begin to tighten about 3/4 to 1 turn in.
Old 01-24-2022, 02:15 PM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
Check the area for cracks in the tank as well, as sometimes the tanks can crack near the bung (especially around the corners of the bung). Mine was; had to have a radiator shop braze it up for me.
Old 01-29-2022, 08:22 AM
Workingstiff Workingstiff is offline
Good info for future use...
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 02-07-2022, 01:22 PM
sorner's Avatar
sorner sorner is offline
If you do use a torch, make sure the gas is all out of it... or you'll need new nipples.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
