Old 02-03-2022, 03:22 PM
Wntsom4 Wntsom4 is offline
Default Is there a filler on the steering wheel at the nut?
Just finished my 1250 restoration and putting back on the decals.
It no longer had the decal on top of the steering wheel but I remember it back when I was a kid. (Long arrowhead style matched the dimpled texture of the console)
My question is I can see the new decal sticking to the flat areas but not over the steering column nut. Was there something under the decal to smooth that area out for the decal to adhere in that area?
Old 02-03-2022, 03:27 PM
Nothing on my 1450.
Old 02-03-2022, 04:21 PM
There should have been a triangular textured piece of thin aluminum, like the dash tin, covering the center of the wheel.
The decal was secured with glue of some sort and a tiny screw.
You will find the hole for the screw at the narrow end of the wheel core where the cover fastened.
Old 02-03-2022, 05:03 PM
If you have the thin decal, repo, you will have to make your own triangle to stick the decal to...
Up to 534 and counting...
Old 02-04-2022, 06:54 AM
ironman's Avatar
ironman ironman is offline
I have used very thin aluminum flashing as a backer for the decal,
and used thin double-sided tape such as for holding carpet down,
to stick the back of the aluminum to the steering wheel hub.
If you need to get the steering wheel off, you can peel the aluminum off
with the decal intact and re-apply with new tape.
