Old 02-06-2022, 09:16 PM
Swartzzz Swartzzz is offline
Default 782 Starter Engagement
Good Afternoon.
I have a 782 that has been sitting a good 15yrs. For some reason, the starter engagement of the bendix is spotty at best.
Is it possible to lubricate the bendix / shaft or the bearing without removal of the engine? Are there any tricks to get this?
I see that you can remove the left engine cover and access..
Let me know.
Greg
Old 02-07-2022, 07:22 AM
Welcome to OCC..........
YES, it is possible. BTDT. You will need some long extension(s) on a Ratchet & Socket. I used a 1/4" drive and about 12" worth of extensions. Patience is the key.
The Bendix can be cleaned, or a new Bendix kit can be installed, or a whole new starter.
Old 02-07-2022, 07:42 AM
Just my 2 cents but I would pull the engine out, remove the tins and give it a good cleaning. If it's been sitting for 15 years it's very possible it has a mouse condo under the tins.
Old 02-07-2022, 08:29 AM
Yup!
That'll do it!!
Old 02-07-2022, 10:41 AM
You can try squirting some garage door lubricant on the starter shaft using the provided straw to aim it at the shaft/bushing area.
Now as far as the starter overrunning clutch,( sometimes called a bendix) kohler makes a specail lubricant that they use, I still have some, but it is NLA.
Most times they will free up with repeated usage.
I have replaced the starter without removing the engine and with removing the engine. both are a pain in the arse, but easier with the engine out, and you get to clean things, as others said and replace necessary driveline parts that are always worn.
