Hi fellas, fairly new to cubs. I have a question about sleeve hitches. Can you add/put one on any cub that doesn't have one. Is it expensive or difficult. Also, are the Brinly implements plentiful or expensive. I live in East Tennessee, if that makes any difference. I came from a small 20 acre farm in Michigan 6 years ago, just got 1 acre now so don't need a big tractor. I'm thinking a cub will fit the bill. Sorry for long post, just a little background. Thanx, Scott.
Yes, you can add them to pretty much any narrow/wide frame cub. Newer ones get tricky -- what model do you have?
I would look for something with hydro lift for heavy rear implement/usage, so oldest being 149/169 up through the Cyclops series. A 782/1711/1811 would be a great start to look for cheaper on marketplace, preferably with the Magnum (1811/2) or KT 17 Series II line engine. Brinly is plentiful but $$$
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
You will need the IH three-point setup before you can utilize the sleeve hitch components.
Typical 3 point for a narrow frame, https://cdn.datamanager.arinet.com/i...b75c487/Medium |
Thanks for the replys so quickly. No cub yet. Just wanting to know so when I come across one ,I know that it doesn't need to have the sleeve hitch. But that I can add one to the tractor. Thanx again. Scott
Checkout extreme motor works, he custom builds rear hitches bring a napkin because his products will leave you drooling.
A 3 point would look like this:
Well, not according to IH ?
David |
Narrow frame, wide frame or 82 series.
They all take a different 3 point setup When/if you get a Cub, look for whatever setup it requires. A Cat O would work best with Cat O implements but can be utilized with sleeve hitch implements by use of a sleeve hitch adapter. Confused yet?? |
Isn't it well regarded that Cat 0 is the smallest 3 point?
Conventionally the other style has always been called a sleeve hitch outside of literature made before the 3 point system was "standardized."
