Old 02-13-2022, 10:59 AM
That_cub_dude1847 That_cub_dude1847 is offline
Default Cub Cadet Original Gears Grind with Clutch Yoke correctly adjusted
I have been doing some winter work on my '62 Cub Cadet Original. Recently I started it up and the gears grinded awfully with the clutch fully depressed. Couldn't even go into a gear, I might as well have not been using the clutch at all. Spent a good hour playing with the clutch yoke trying to get it between 0.020-0.030 in and I got it correctly, but it grinds just as bad as before. Another thing to include is that the clutch release collar does not return to its oriinal position. I would press the clutch in moving the collar forward, After releasing, the operating yoke would return to its original position, but the collar wouldn't. Any Ideas? I'm afraid to destroy my gearbox any further.
File Type: jpg Screen Shot 2022-02-13 at 10.57.47 AM.jpg (15.7 KB, 69 views)
File Type: jpg Screen Shot 2022-02-13 at 10.58.12 AM.jpg (20.1 KB, 69 views)
Old 02-13-2022, 11:40 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Is the frame broken near the transmission thus causing a misalignment in the drive shaft?
Queen Of The Quietlines!
Old 02-13-2022, 01:24 PM
No, the frame is straight and no cracks
Old 02-13-2022, 01:58 PM
Driveshaft alignment and/or throw out bearing issue.
Old 02-13-2022, 03:07 PM
Red Dave Red Dave is offline
I'm not familiar with Cub Cadet clutches as I have only Hydro's, so I may be way off. But if somebody described those symptoms and told me they were happening on a Farmall A, I would tell them that either their clutch wasn't releasing, or the pilot bearing was dry and binding.
If it was me, I'd check whatever the equivalent to those is on a Cub Cadet.
Just a thought.
Old 02-13-2022, 03:35 PM
The clutch plate may be frozen to the drive disc from sitting a long time.
Up to 534 and counting...
