Old 08-22-2010, 04:22 PM
dgard dgard is offline
Default Model 3225 98 year Brake switch issue
Tractor starts with brake in won't run when brake is disengaged. Repaleced the switch for the brake pedal with an aftermarket universal switch. Same result so put old switch back on and taped it closed (simulate brake engaged) wow tractor starts stay running however now the mower deck/PTO will not engage and run??????
Was the new rpl switch not correct?
Does old switch also disengage the PTO mower deck when fully depressed?
No what new switch didn't help, old switch starts tractor motor when fully depressed but will not run the PTO mower deck??? can't win!
Old 08-22-2010, 04:30 PM
You might have to get the one from a dealer and not a universial switch. Go here to locate your switch or contact your cub dealer for the correct switch.
http://www.cubcadet.com/webapp/wcs/s...1_1100505_Y_-1
I hope it works out for you!
