Old 03-10-2022, 01:34 PM
bdale bdale is offline
Default Fuel pump kit
Anyone have a source or a part number for a fuel pump kit for a 23HP Kohler command engine, would like to keep my valve cover
Old 03-10-2022, 02:05 PM
Since we don't have a Kohler or Cub Cadet Model Number, it is hard and would only be a guess.
Old 03-10-2022, 07:03 PM
ejl6658 ejl6658 is offline
My experience has been you need to buy a replacement pump which includes a new valve cover. They are readily available.
Old 03-11-2022, 11:44 AM
Farmall450's Avatar
Same here.
Old 03-11-2022, 05:48 PM
Yeah OK thanks by the way it's a 3235
Don't see the use of buying a complete valve cover assembly when it has a simple diaphragm
Old 03-11-2022, 09:12 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
Not much use to it then.
I've never seen a kit for them, other than the one that comes with a new valve cover and new pump.
I just replace them with a vacuum pump.
JD x475
Old 03-12-2022, 12:39 AM
Ozcub's Avatar
Ozcub Ozcub is offline
Try part number KH-24559-08-s that is Cover Kit - Fuel pump valve
Oz
