Have a 1985'ish 2165 that makes a slight ratchet sound, from right rear. The sound is made only in right turns. Was planning on changing transmission filter & oil, but wanted to see if this sound may be indicator of something going south..
Let me know if anyone has idea on what sound is about and/or recommended options to determine if there is an issue Looking to use Amsoil 20/50 Hy-Tran oil or another quality product if have suggestion. Thanks |
The 2165 was produced '94-'99.
Per the owners manual: Use Cub Cadet "Drive System Oil" part number 737-3055 or a 20W50 oil that meets API service class SG/CD, which is an antiquated SG from when the tractor was new. The special drive system oil's part number is now currently 737-3120. It is very expensive at $17 a quart!
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
Do not use Hy-Tran. You don't want the moisture clumping up in the rear with no way to get it out. I wouldn't pay $17/quart for snake oil either. This stuff will work fine and is priced fair.
https://www.tractorsupply.com/tsc/se...aulic%20fluid?
Thanks for responding. Yes, the Amsoil meets the specified criteria for transmission oil. Just would like to figure the noise out before going through oil change.
Forgot to ask if anyone knows how to determine the mftr of a transmission? Believe the one that I have is a Hydro-Gear, but cannot find any identifying marks.
I'm not sure about who made the trans.
I am sure the tractor supply oil works just fine. You can even pick it up in 2 gallon jugs for around $20.
JD x475 |
Yes, it is a Hydro-Gear BDU-10L-XXX.
Go here and find which version of the BDU-10L you have. Click the Cub Cadet logo and enter your model/serial numbers https://www.cubcadet.com/en_US/conte...artstream.html You can go here and get the manual if you don't already have it. https://www.hydro-gear.com/service-repair-manuals/
Thank you for the information. Found HG label on transmission, but the manual for the BDU model is just a spec sheet & no other info. Nonetheless, will look into the TSC oil, sounds like a plan.Tks
Sorry about that, I didn't check the link. Here is the service manual and it shows which oils are approved.
https://www.sauerbibus.de/fileadmin/...air_Manual.pdf
This is what i have been using for years without any dramas , actually will be doing an oil change shortly
!00 hours on the oil easy as and the oil still looks and feels brand new Oz
My wife says I do not listen , at least I think thats what she said |
