Old 03-25-2022, 06:22 AM
Steve N Mi Steve N Mi is offline
Default Removing old decal adhesive on my 1872
I've tried lots of cleaners, some pretty powerful ones - not paint remover yet. I would like to get this goo off so I can paint followed by another set of decals.
If you have found a magical decal remover, please share! TIA Steve
Old 03-25-2022, 08:12 AM
How about heat, like from a Hair Dryer ??
Old 03-25-2022, 08:31 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
I used an industrial heat gun to remove most of the decal and enamel reducer to remove of what adhesive remained on my 1811. To ensure that the finish is not harmed by the reducer you are using, try on a hidden area. 3M does market adhesive remover.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 03-25-2022, 10:12 AM
This is what I use at work.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 03-25-2022, 11:09 AM
Farmall450's Avatar
^That's the stuff I use.
Old 03-25-2022, 06:51 PM
Ozcub's Avatar
Ozcub Ozcub is offline
To remove the sticky goo that remains try Eucalyptus oil
Oz
Old 03-26-2022, 01:48 AM
cubby102's Avatar
cubby102 cubby102 is offline
Little bit of heat and some pb blaster will do the trick.
Of course clean really well with acetone or something before putting the new decal on.
Old 03-26-2022, 10:34 PM
Thanks for all the suggestions, good ideas all. I need to get a plastic squeegee/scraper(s), some Rapid Remover and Eucalyptus oil. I have a heat gun and most anything else mentioned. Steve
Old 03-28-2022, 03:47 PM
Clodhopper Clodhopper is offline
Heat gun or hair dryer to remove decal. Acetone will make short work of the adhesive. Wear gloves.
Old 04-06-2022, 03:22 AM
Ozcub's Avatar
Steve
Well what worked the best ????
Oz
